Giriş
If your keyboard on your Dell Inspiron N5030 is not working, and you have tried all of the steps on the troubleshooting guide, use this guide to replace your keyboard.
Neye ihtiyacın var
Turn the computer over on its back so the battery compartment faces towards you.
Place your fingers on the small buttons with arrows pointing outwards.
Push and slide the buttons outward to unlock the battery compartment.
Use a Phillips #0 screwdriver to unscrew the sixteen 0.6 mm screws on the back panel.
5 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
What if i broke the blue ribbons connection to the keyboard
This solution is quite troublesome and does not explain how to disconnect / re-connect the wide flat keyboard cable. For a simpler solution see :
