Ana içeriğe geç
Dell Inspiron N5050 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron N5050 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your laptop over to view the bottom and the two locks.
  2. Dell Inspiron N5050 RAM Replacement: adım 2, 1 resimden 1.
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 RAM Replacement: adım 3, 2 resimden 1. Dell Inspiron N5050 RAM Replacement: adım 3, 2 resimden 2.
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 RAM Replacement, RAM: adım 4, 1 resimden 1.
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron N5050 RAM Replacement: adım 5, 2 resimden 2.
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 RAM Replacement: adım 6, 3 resimden 1. Dell Inspiron N5050 RAM Replacement: adım 6, 3 resimden 2. Dell Inspiron N5050 RAM Replacement: adım 6, 3 resimden 3.
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 RAM Replacement: adım 7, 3 resimden 1. Dell Inspiron N5050 RAM Replacement: adım 7, 3 resimden 2. Dell Inspiron N5050 RAM Replacement: adım 7, 3 resimden 3.
    • Find the RAM and pull apart the two clips.
    • After pulling apart both clips, the RAM component will snap up.
  8. Dell Inspiron N5050 RAM Replacement: adım 8, 2 resimden 1. Dell Inspiron N5050 RAM Replacement: adım 8, 2 resimden 2.
    • Remove the RAM.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Kristy Mayo
1.394 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
Thanks Kristy,
I was breath new life back into an old laptop and re-purpose after upgrading the RAM.
jason acn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 2,393
