Ana içeriğe geç
Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement, WiFi Half Mini PCI card: adım 1, 3 resimden 1. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement, WiFi Half Mini PCI card: adım 1, 3 resimden 2. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement, WiFi Half Mini PCI card: adım 1, 3 resimden 3.
    • Switch off the laptop and remove the battery.
    • The keyboard is held by 4x locking clips.
    • By using cutter, carefully lift up the one side of the keyboard and start opening the locking clips.
  2. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: adım 2, 3 resimden 1. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: adım 2, 3 resimden 2. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: adım 2, 3 resimden 3.
    • Disconnect the keyboard cable and remove the keyboard.
    • Remove the access door screw and the access door
    • Remove the screw securing the optical drive, and remove the optical drive
  3. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: adım 3, 3 resimden 1. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: adım 3, 3 resimden 2. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: adım 3, 3 resimden 3.
    • Remove all the screws
    • Pry the upper plastic casing off of the laptop
  4. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: adım 4, 3 resimden 1. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: adım 4, 3 resimden 2. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: adım 4, 3 resimden 3.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
ZFix
191.368 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.545 adet Kılavuz yazıldı
2 Yorum
Great, cogent step by step. You alleviated the need to watch a video while including all of the key steps. Nicely done. I replaced a hard drive last year and I would have preferred this format.
Robert Gemkow - Yanıt
Hi, do you know if there is a whitelist for wifi adapters in this notebook?
Artem White - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 30
Her zaman: 7,309
