Ana içeriğe geç
Dell Inspiron One 2020 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: adım 1, 3 resimden 1. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: adım 1, 3 resimden 2. Dell Inspiron One 2020 Hard Drive Replacement, Back Cover: adım 1, 3 resimden 3.
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Dell Inspiron One 2020 Hard Drive Replacement: adım 2, 3 resimden 1. Dell Inspiron One 2020 Hard Drive Replacement: adım 2, 3 resimden 2. Dell Inspiron One 2020 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Dell Inspiron One 2020 Hard Drive Replacement: adım 3, 3 resimden 1. Dell Inspiron One 2020 Hard Drive Replacement: adım 3, 3 resimden 2. Dell Inspiron One 2020 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
  4. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Dell Inspiron One 2020 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Remove the three screws that hold the hard drive cage to the chassis.
  5. Dell Inspiron One 2020 Hard Drive Replacement: adım 5, 2 resimden 1. Dell Inspiron One 2020 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Slide the hard drive cage out slightly to access and remove the power and SATA cable.
    • There isn't much slack in these cables, so don't slide the hard drive cage to far.
    • The power and SATA cables are connected together. On most other computers, these connectors are separate.
    • Lift the hard drive cage out.
  6. Dell Inspiron One 2020 Hard Drive Replacement: adım 6, 3 resimden 1. Dell Inspiron One 2020 Hard Drive Replacement: adım 6, 3 resimden 2. Dell Inspiron One 2020 Hard Drive Replacement: adım 6, 3 resimden 3.
    • Remove the four screws (two on each side) that attach the hard drive cage to the hard drive.
    • Lift the hard drive cage off the hard drive.
    Excellent guide, was a super easy swap. I put an SSD in it!!
    Matt Yakel - Yanıt
    Hey Just one question, is the HDD SATA 2 or SATA 3? Just wanted to know so I can purchase an SDD with the correct specification.
    Jeffery Epstein - Yanıt
Sonuç
35 farklı kişi bu kılavuzu tamamladı.
Tyler
4.920 İtibar
16 adet Kılavuz yazıldı
Ekip
TechForce TechForce üyesi
Business
2 Üyeler
25 adet Kılavuz yazıldı
3 Yorum
Thanks for this info this is very useful
Thank you once again
Ketan Valsangkar - Yanıt
Good Job, short and sweet and easy to follow
schmidtrg - Yanıt
Really useful information thank you.
Jessie Colon - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 81
Her zaman: 35,763
