Ana içeriğe geç
Giriş
This guide will teach you how to replace the surface around the keyboard in the Dell Inspiron M5030.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop. Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
    • Remove all fourteen Phillips #0 7/16" screws from the bottom of the laptop.
    • Remove the two Phillips #0 5/16" screws from the bottom of the laptop.
  2. Turn the laptop over and open the lid. Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
    • Turn the laptop over and open the lid.
    • Locate the three tabs above the first row of keys on the top of the keyboard, found above the F1, F6, and PrntScr keys.
    • With one of your hands, push the leftmost tab down with the plastic opening tool (above the F1 key). With your other hand, lift the left side of the keyboard.
    • Push the middle tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the F6 key).
    • Push the rightmost tab down with the plastic opening tool and continue lifting from the left side of the keyboard to the right side (above the PrntScr key). The keyboard should be loosened from the laptop after these steps.
  3. After the top edge of the keyboard is loose, pull up on the keyboard gently. Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by  a ribbon.
    • After the top edge of the keyboard is loose, pull up on the keyboard gently.
    • Do not pull the keyboard up forcefully as the keyboard is still attached to the laptop by a ribbon.
  4. Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard. Locate the blue end of the ribbon which is connected to the motherboard. Lift up the black flap on the connector and gently pull the ribbon away from the connector  which is parallel to the motherboard.
    • Pull up the bottom side of the keyboard and locate the ribbon connecting the keyboard to the motherboard.
    • Locate the blue end of the ribbon which is connected to the motherboard.
    • Lift up the black flap on the connector and gently pull the ribbon away from the connector which is parallel to the motherboard.
    • Lift the keyboard up and off of the motherboard. Detach the blue end of the ribbon from the connector.
  5. Disconnect the blue tab located just above the touch pad of the laptop. Disconnect the blue tab located just above the touch pad of the laptop.
    • Disconnect the blue tab located just above the touch pad of the laptop.
  6. Use a plastic opening tool to pry up the plastic covering of the laptop by wedging it underneath one side of the covering and lift up. Do not lift off the cover all the way as it is still connected by two wires on the side nearest to the screen.
    • Use a plastic opening tool to pry up the plastic covering of the laptop by wedging it underneath one side of the covering and lift up.
    • Do not lift off the cover all the way as it is still connected by two wires on the side nearest to the screen.
  7. Disconnect the white block of wires which is  the right-most wire connecting the covering to the laptop. Disconnect the white block of wires which is  the right-most wire connecting the covering to the laptop. Disconnect the white block of wires which is  the right-most wire connecting the covering to the laptop.
    • Disconnect the white block of wires which is the right-most wire connecting the covering to the laptop.
  8. Disconnect the wire with the blue tab which is the left-most wire connecting the covering to the laptop. You can now remove the plastic covering. You can now remove the plastic covering.
    • Disconnect the wire with the blue tab which is the left-most wire connecting the covering to the laptop.
    • You can now remove the plastic covering.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Marek Moreno
434 İtibar
2 adet Kılavuz yazıldı
Takım
Cal Poly, Team 3-44, Maness Spring 2014 Cal Poly, Team 3-44, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G44
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 632
