Ana içeriğe geç
Dell Inspiron n5110 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron n5110 Display Assembly Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the computer base.
  2. Dell Inspiron n5110 Display Assembly Replacement, Disconnecting the Display Cable: adım 2, 1 resimden 1.
    • Disconnect the display cable and touch-screen cable from the system-board connectors.
    • NOTE: The touch-screen board is optional and may not be present in your computer.
  3. Dell Inspiron n5110 Display Assembly Replacement, Note the Routing: adım 3, 1 resimden 1.
    • Note the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
  4. Dell Inspiron n5110 Display Assembly Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the four screws that secure the display assembly to the computer base.
  5. Dell Inspiron n5110 Display Assembly Replacement, Lifting the Display Assembly.: adım 5, 1 resimden 1.
    • Lift the display assembly off the computer base.
  6. Dell Inspiron n5110 Display Assembly Replacement, Placing the Display Assembly: adım 6, 1 resimden 1.
    • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  7. Dell Inspiron n5110 Display Assembly Replacement, Route the Cables: adım 7, 1 resimden 1.
    • Route the Mini-Card antenna cables through the routing guides.
  8. Dell Inspiron n5110 Display Assembly Replacement, Connect the Display Cable: adım 8, 1 resimden 1.
    • Connect the display cable and touch-screen cable to the connectors on the system board.
  9. Dell Inspiron n5110 Display Assembly Replacement, Replace the Screws: adım 9, 1 resimden 1.
    • Replace the two screws that secure the display assembly to the computer base.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Terrence15
78.818 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.984 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 1,958
