Ana içeriğe geç
Dell Inspiron n5110 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron n5110 Hard Drive Replacement, Remove the Screws: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the system board.
  2. Dell Inspiron n5110 Hard Drive Replacement, Sliding the Hard Drive Assembly: adım 2, 1 resimden 1.
    • Slide the hard-drive assembly to disconnect it from the system-board connector.
  3. Dell Inspiron n5110 Hard Drive Replacement, Lifting the Hard-Drive Assembly: adım 3, 1 resimden 1.
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron n5110 Hard Drive Replacement, Remove the Screws: adım 4, 1 resimden 1.
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  5. Dell Inspiron n5110 Hard Drive Replacement, Lifting the Hard Drive: adım 5, 1 resimden 1.
    • Lift the hard drive away from the hard-drive bracket.
  6. Dell Inspiron n5110 Hard Drive Replacement, Placing the Hard Drive: adım 6, 1 resimden 1.
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron n5110 Hard Drive Replacement, Replace the Screws: adım 7, 1 resimden 1.
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  8. Dell Inspiron n5110 Hard Drive Replacement, Placing the Hard-Drive Assembly: adım 8, 1 resimden 1.
    • Place the hard-drive assembly on the system board.
  9. Dell Inspiron n5110 Hard Drive Replacement, Sliding the Hard-Drive Assembly: adım 9, 1 resimden 1.
    • Slide the hard-drive assembly to connect it to the system-board connector.
  10. Dell Inspiron n5110 Hard Drive Replacement, Replace the Screws: adım 10, 1 resimden 1.
    • Replace the two screws that secure the hard-drive assembly to the system-board.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Terrence15
78.818 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.984 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 30
Her zaman: 2,720
