Ana içeriğe geç
Dell Latitude 10-ST2e Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude 10-ST2e Battery Replacement, Battery: adım 1, 3 resimden 1. Dell Latitude 10-ST2e Battery Replacement, Battery: adım 1, 3 resimden 2. Dell Latitude 10-ST2e Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Place tablet face-down on flat surface.
    • Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Battery Replacement: adım 2, 2 resimden 1. Dell Latitude 10-ST2e Battery Replacement: adım 2, 2 resimden 2.
    • Remove the four 7.0mm screws securing the battery with a JIS #00 screwdriver.
  3. Dell Latitude 10-ST2e Battery Replacement: adım 3, 2 resimden 1. Dell Latitude 10-ST2e Battery Replacement: adım 3, 2 resimden 2.
    • With the blue opening tool, gently lift up and remove the battery from the tablet.
    • Do not damage, puncture, cut, or bend the battery, as this may cause bodily harm.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Vincent Hoffman
261 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G4, Eyestone Fall 2017 USF Tampa, Team S16-G4, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S16G4
4 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
I found that the down volume control was jammed by the case. So be careful with the reassembly around the volume control.
James Smith - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 16
Son 30 gün: 24
Her zaman: 2,423
