Ana içeriğe geç
Dell Latitude 10-ST2e Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Dell Latitude 10-ST2e Rear Facing Camera Replacement, Motherboard: adım 1, 3 resimden 1. Dell Latitude 10-ST2e Rear Facing Camera Replacement, Motherboard: adım 1, 3 resimden 2. Dell Latitude 10-ST2e Rear Facing Camera Replacement, Motherboard: adım 1, 3 resimden 3.
    • Using the blue opening tool, separate the back plastic cover from the device. Start in a corner, and work your way around the tablet.
  2. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 2, 2 resimden 1. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 2, 2 resimden 2.
    • Remove the four 4.0mm black screws on the perimeter of the device using a JIS #00 screwdriver
  3. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 3, 2 resimden 1. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 3, 2 resimden 2.
    • Remove the two 4.0mm silver screws using the JIS #00 screwdriver.
  4. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the connection of the front camera clamp by releasing the clamp with tweezers.
    • Pull up on the connection from the motherboard.
    • Avoid damaging the connection.
  5. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 5, 3 resimden 1. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 5, 3 resimden 2. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 5, 3 resimden 3.
    • Using an opening tool, lift upwards on the white clamp, and pull the blue tab out of the connection with tweezers.
  6. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 6, 2 resimden 1. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 6, 2 resimden 2.
    • Using tweezers, disconnect the white and black wires from the bottom of the motherboard.
    • Pull upwards while holding the brass connections. Do not pull on the wires.
  7. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 7, 3 resimden 1. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 7, 3 resimden 2. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 7, 3 resimden 3.
    • Disconnect the two clamps, one orange and one white, using tweezers next to the battery.
  8. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 8, 1 resimden 1.
    • Remove the four 7.0mm screws securing the battery with a JIS #00 screwdriver.
  9. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 9, 2 resimden 1. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 9, 2 resimden 2.
    • With the blue opening tool, gently lift up and remove the battery from the tablet.
    • Do not damage, puncture, cut, or bend the battery, as this may cause bodily harm.
  10. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 10, 3 resimden 1. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 10, 3 resimden 2. Dell Latitude 10-ST2e Rear Facing Camera Replacement: adım 10, 3 resimden 3.
    • Rotate the motherboard upwards from the tablet using tweezers, but do not remove completely from the device. As you lift, disconnect the black and red wire located underneath the motherboard before removing it completely from the tablet.
  11. Dell Latitude 10-ST2e Rear Facing Camera Replacement, Rear Facing Camera: adım 11, 3 resimden 1. Dell Latitude 10-ST2e Rear Facing Camera Replacement, Rear Facing Camera: adım 11, 3 resimden 2. Dell Latitude 10-ST2e Rear Facing Camera Replacement, Rear Facing Camera: adım 11, 3 resimden 3.
    • Once the motherboard is removed, place on a flat surface facing down. Use the plastic opening tool to disconnect and remove the camera from the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jan Camacho
140 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S16-G4, Eyestone Fall 2017 USF Tampa, Team S16-G4, Eyestone Fall 2017 üyesi
USFT-EYESTONE-F17S16G4
4 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 248
