Giriş
One common issue that laptop users may encounter is a malfunctioning or damaged power jack, otherwise known as a charging port. You may notice that the charger slips out of the port, or that the port is wobbling and loose.
This component is crucial for powering up and recharging the device, and can experience various problems due to frequent use, mishandling, or manufacturing defects. This short guide will assist you in removing and replacing the charging port.
Neye ihtiyacın var
Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
Use a spudger to push the charging port connector directly out of its motherboard port.
