Ana içeriğe geç
Dell Latitude 3189 Power Jack Replacement
Neye ihtiyacın var
  1. Dell Latitude 3189 Power Jack Replacement, Lower Case: adım 1, 2 resimden 1. Dell Latitude 3189 Power Jack Replacement, Lower Case: adım 1, 2 resimden 2.
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Power Jack Replacement: adım 2, 3 resimden 1. Dell Latitude 3189 Power Jack Replacement: adım 2, 3 resimden 2. Dell Latitude 3189 Power Jack Replacement: adım 2, 3 resimden 3.
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Power Jack Replacement: adım 3, 2 resimden 1. Dell Latitude 3189 Power Jack Replacement: adım 3, 2 resimden 2.
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Power Jack Replacement: adım 4, 3 resimden 1. Dell Latitude 3189 Power Jack Replacement: adım 4, 3 resimden 2. Dell Latitude 3189 Power Jack Replacement: adım 4, 3 resimden 3.
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Power Jack Replacement, Power Jack: adım 5, 1 resimden 1.
    • Use a spudger to push the charging port connector directly out of its motherboard port.
    • The charging port is located in the top-right corner of the device, near the hinge.
  6. Dell Latitude 3189 Power Jack Replacement: adım 6, 2 resimden 1. Dell Latitude 3189 Power Jack Replacement: adım 6, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the two 3.3 mm screws that secure the power jack to the chassis.
  7. Dell Latitude 3189 Power Jack Replacement: adım 7, 1 resimden 1.
    • Slide and lift the power connector port away from the computer.
Sonuç
Bryan Pratt
601 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 45
