Ana içeriğe geç
Dell Latitude 3190 Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude 3190 Battery Replacement, Base Cover: adım 1, 2 resimden 1. Dell Latitude 3190 Battery Replacement, Base Cover: adım 1, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Battery Replacement: adım 2, 3 resimden 1. Dell Latitude 3190 Battery Replacement: adım 2, 3 resimden 2. Dell Latitude 3190 Battery Replacement: adım 2, 3 resimden 3.
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Locate the battery.
  4. Dell Latitude 3190 Battery Replacement: adım 4, 3 resimden 1. Dell Latitude 3190 Battery Replacement: adım 4, 3 resimden 2. Dell Latitude 3190 Battery Replacement: adım 4, 3 resimden 3.
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Battery Replacement: adım 5, 3 resimden 1. Dell Latitude 3190 Battery Replacement: adım 5, 3 resimden 2. Dell Latitude 3190 Battery Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Battery Replacement: adım 6, 3 resimden 1. Dell Latitude 3190 Battery Replacement: adım 6, 3 resimden 2. Dell Latitude 3190 Battery Replacement: adım 6, 3 resimden 3.
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
Sonuç
Daniel Tzunum
214 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-5, Saknee Fall 2021 Gateway, Team 1-5, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G5
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 14
Son 30 gün: 52
Her zaman: 1,546
