Ana içeriğe geç
Dell Latitude 3190 M.2 SSD Replacement
Neye ihtiyacın var
  1. Dell Latitude 3190 M.2 SSD Replacement, Base Cover: adım 1, 2 resimden 1. Dell Latitude 3190 M.2 SSD Replacement, Base Cover: adım 1, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 M.2 SSD Replacement: adım 2, 3 resimden 1. Dell Latitude 3190 M.2 SSD Replacement: adım 2, 3 resimden 2. Dell Latitude 3190 M.2 SSD Replacement: adım 2, 3 resimden 3.
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 M.2 SSD Replacement, M.2 SSD: adım 3, 3 resimden 1. Dell Latitude 3190 M.2 SSD Replacement, M.2 SSD: adım 3, 3 resimden 2. Dell Latitude 3190 M.2 SSD Replacement, M.2 SSD: adım 3, 3 resimden 3.
    • Use a spudger to disconnect the battery cable from the motherboard located at the top of the battery.
  4. Dell Latitude 3190 M.2 SSD Replacement: adım 4, 3 resimden 1. Dell Latitude 3190 M.2 SSD Replacement: adım 4, 3 resimden 2. Dell Latitude 3190 M.2 SSD Replacement: adım 4, 3 resimden 3.
    • Locate the M.2 SSD after the battery is removed
    • Use the Phillips #0 screwdriver to remove the 3 mm screw from the SSD.
    • Pull the M.2 SSD from the board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Tzunum
235 İtibar
2 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-5, Saknee Fall 2021 Gateway, Team 1-5, Saknee Fall 2021 üyesi
GCC-SAKNEE-F21S1G5
3 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
It's worth noting that some Latitude 3190s use eMMC storage, and these lack the M2 socket on the motherboard, although it would be possible to solder one on (the 80mm standoff and screw are present!)
Tim Walker - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 25
Son 30 gün: 147
Her zaman: 4,258
