Ana içeriğe geç
Dell Latitude 3380 Keyboard Replacement
Neye ihtiyacın var
    1. Dell Latitude 3380 Keyboard Replacement, Back Cover: adım 1, 2 resimden 1. Dell Latitude 3380 Keyboard Replacement, Back Cover: adım 1, 2 resimden 2.
      • Turn the laptop over so that the back is facing up.
      • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Latitude 3380 Keyboard Replacement: adım 2, 2 resimden 1. Dell Latitude 3380 Keyboard Replacement: adım 2, 2 resimden 2.
      • Use an opening tool to pry the back cover away from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Latitude 3380 Keyboard Replacement, Battery: adım 3, 3 resimden 1. Dell Latitude 3380 Keyboard Replacement, Battery: adım 3, 3 resimden 2. Dell Latitude 3380 Keyboard Replacement, Battery: adım 3, 3 resimden 3.
      • Remove the three 3 mm screws using a Phillips #0 screwdriver
      • Disconnect the the cable connected to the battery using a spudger.
      • Lift up on the outer edges of the battery to remove it from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Latitude 3380 Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. Dell Latitude 3380 Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
      • Disconnect the blue ribbon cable with the letters "MB" on it from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Latitude 3380 Keyboard Replacement: adım 5, 2 resimden 1. Dell Latitude 3380 Keyboard Replacement: adım 5, 2 resimden 2.
      • Flip the laptop over and open the lid.
      • Use a spudger to push the bezel of the keyboard towards the display.
      • On the back of laptop, you can use the two holes marked with "KB" to help pop out the keyboard by using the pointed edge of the spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Latitude 3380 Keyboard Replacement: adım 6, 2 resimden 1. Dell Latitude 3380 Keyboard Replacement: adım 6, 2 resimden 2.
      • Once the keyboard is loose, pull the disconnected MB cable through the slot and remove the keyboard from the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Medina
137 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Pee Fall 2021 Gateway, Team 1-3, Pee Fall 2021 üyesi
GCC-PEE-F21S1G3
3 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 45
Her zaman: 1,421
