Ana içeriğe geç
Dell Latitude 3500 IO Board Replacement
Neye ihtiyacın var
  1. Dell Latitude 3500 IO Board Replacement, Remove screws: adım 1, 1 resimden 1.
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 IO Board Replacement, Separate bottom cover and palmrest: adım 2, 1 resimden 1.
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 IO Board Replacement, Disconnect and Remove Battery: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 IO Board Replacement, Disconnect Ribbon Cable: adım 4, 1 resimden 1.
    • Small latch holding it in place
  5. Dell Latitude 3500 IO Board Replacement, Remove Screws: adım 5, 1 resimden 1.
    • 2 screws total
    • Board can now be removed
Sonuç
Jake
1.336 İtibar
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 123
