Ana içeriğe geç
Dell Latitude 3500 Power Button Board Replacement
Neye ihtiyacın var
  1. Dell Latitude 3500 Power Button Board Replacement, Remove screws: adım 1, 1 resimden 1.
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 Power Button Board Replacement, Separate bottom cover and palmrest: adım 2, 1 resimden 1.
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 Power Button Board Replacement, Disconnect and Remove Battery: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 Power Button Board Replacement, Disconnect Surrounding Connections from System Fan: adım 4, 1 resimden 1.
    • Unplug the fan header
    • Unplug the VGA board cable
    • Unplug the LCD cable
  5. Dell Latitude 3500 Power Button Board Replacement, Remove Fan Screws: adım 5, 1 resimden 1.
    • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
  6. Dell Latitude 3500 Power Button Board Replacement, Disconnect Ribbon Cable: adım 6, 1 resimden 1.
    • Insert wisdom here.
  7. Dell Latitude 3500 Power Button Board Replacement, Lift Left-Side Hinge: adım 7, 1 resimden 1.
    • 2 screws total
  8. Dell Latitude 3500 Power Button Board Replacement, Remove Board: adım 8, 1 resimden 1.
    • 2 screws total
Sonuç
Jake
1.300 İtibar
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 43
