Ana içeriğe geç
Dell Latitude 3520 RAMReplacement
Neye ihtiyacın var
  1. Dell Latitude 3520 RAMReplacement, Remove MicroSD-card: adım 1, 1 resimden 1.
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 RAMReplacement, Bottom Case: adım 2, 3 resimden 1. Dell Latitude 3520 RAMReplacement, Bottom Case: adım 2, 3 resimden 2. Dell Latitude 3520 RAMReplacement, Bottom Case: adım 2, 3 resimden 3.
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 RAMReplacement, RAM: adım 3, 2 resimden 1. Dell Latitude 3520 RAMReplacement, RAM: adım 3, 2 resimden 2.
    • Lift the clips to find the memory module slot.
Sonuç
Shawn Smith
871 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 122
