Ana içeriğe geç
Dell Latitude 3520 Speaker Replacement
Neye ihtiyacın var
  1. Dell Latitude 3520 Speaker Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the metal above the connector on the battery to unlock.
  2. Dell Latitude 3520 Speaker Replacement: adım 2, 2 resimden 1. Dell Latitude 3520 Speaker Replacement: adım 2, 2 resimden 2.
    • Peel the adhesive tapes and the battery cable.
  3. Dell Latitude 3520 Speaker Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Latitude 3520 Speaker Replacement: adım 4, 2 resimden 1. Dell Latitude 3520 Speaker Replacement: adım 4, 2 resimden 2.
    • Remove the three 2mm Phillip #0 screws that secure the battery in place.
  5. Dell Latitude 3520 Speaker Replacement: adım 5, 1 resimden 1.
    • Lift and remove the battery.
  6. Dell Latitude 3520 Speaker Replacement, Speaker: adım 6, 2 resimden 1. Dell Latitude 3520 Speaker Replacement, Speaker: adım 6, 2 resimden 2.
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Latitude 3520 Speaker Replacement: adım 7, 1 resimden 1.
    • Unroute the speaker cable from the routing guides assembly.
  8. Dell Latitude 3520 Speaker Replacement: adım 8, 1 resimden 1.
    • Peel the adhesive tapes, lift them, and remove the speakers.
Sonuç
Shawn Smith
871 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 156
