Ana içeriğe geç
Dell Latitude 3520 System Fan Replacement
Neye ihtiyacın var
  1. Dell Latitude 3520 System Fan Replacement, Remove MicroSD-card: adım 1, 1 resimden 1.
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 System Fan Replacement, Bottom Case: adım 2, 3 resimden 1. Dell Latitude 3520 System Fan Replacement, Bottom Case: adım 2, 3 resimden 2. Dell Latitude 3520 System Fan Replacement, Bottom Case: adım 2, 3 resimden 3.
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 System Fan Replacement, Battery: adım 3, 1 resimden 1.
    • Slide the metal above the connector on the battery to unlock.
  4. Dell Latitude 3520 System Fan Replacement: adım 4, 2 resimden 1. Dell Latitude 3520 System Fan Replacement: adım 4, 2 resimden 2.
    • Peel the adhesive tapes and the battery cable.
  5. Dell Latitude 3520 System Fan Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery cable from the connector on the system board.
  6. Dell Latitude 3520 System Fan Replacement: adım 6, 2 resimden 1. Dell Latitude 3520 System Fan Replacement: adım 6, 2 resimden 2.
    • Remove the three 2mm Phillip #0 screws that secure the battery in place.
  7. Dell Latitude 3520 System Fan Replacement: adım 7, 1 resimden 1.
    • Lift and remove the battery.
  8. Dell Latitude 3520 System Fan Replacement, System Fan: adım 8, 1 resimden 1.
    • Disconnect the system fan cable from the connector on the system board.
  9. Dell Latitude 3520 System Fan Replacement: adım 9, 1 resimden 1.
    • Remove the two 2mm Phillips #0 screws that secure the system fan.
  10. Dell Latitude 3520 System Fan Replacement: adım 10, 1 resimden 1.
    • Lift and remove the system fan.
Sonuç
Shawn Smith
871 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 117
