Giriş
Welcome to this guide on replacing the battery of your Dell Latitude 5310 laptop. A new battery can resolve power issues or bring a fresh life to your device.
Before starting, make sure to have the necessary tools and take safety precautions.
This guide provides a clear and concise process, making replacement straightforward.
Let's begin!
Neye ihtiyacın var
place the laptop upside down on a soft, clean surface to avoid scratching
locate the screws (in this case 8)
use the screwdriver
'Note: the screws are designe to stay attached in the back cover even after being unscrewed. This prevents loss.'
use the opening tool to open the back cover starting on the hinge areas. then move slowly around the edges
lift the open areas with your hand (lightly!) and slowly work using the tension along the edges.
use the screwdriver to remove the screws which also stay attached
use your fingers to detach the battery connection cable from the motherboard
you can pick up the battery and take it out of the device
remove the connections cable from the "old" battery and insert to the new one
insert the new battery and screw in
use the spudger to fix the connection cable then press with the flat of the spudger side to push it in
put the back cover on and use your palm to close softly
then screw the back cover back on
test if the device is working
Note: mostly the batterys are delivered empty so first you need to charge it maybe
its also possible to get the status of the battery: press F2 while starting to open bios settings then check battery status
2 farklı kişi bu kılavuzu tamamladı.
