Ana içeriğe geç
Dell Latitude 5480 Display Replacement
Neye ihtiyacın var
  1. Dell Latitude 5480 Display Replacement, Lower Case: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Display Replacement: adım 2, 3 resimden 1. Dell Latitude 5480 Display Replacement: adım 2, 3 resimden 2. Dell Latitude 5480 Display Replacement: adım 2, 3 resimden 3.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Display Replacement, Battery: adım 3, 2 resimden 1. Dell Latitude 5480 Display Replacement, Battery: adım 3, 2 resimden 2.
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Display Replacement: adım 4, 3 resimden 1. Dell Latitude 5480 Display Replacement: adım 4, 3 resimden 2. Dell Latitude 5480 Display Replacement: adım 4, 3 resimden 3.
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Display Replacement, Display: adım 5, 3 resimden 1. Dell Latitude 5480 Display Replacement, Display: adım 5, 3 resimden 2. Dell Latitude 5480 Display Replacement, Display: adım 5, 3 resimden 3.
    • Insert a plastic card between the bezel and the display.
    • Slide the plastic card beneath the entire bezel to sever the adhesive that secures the bezel.
    • Lift the bezel off of the display.
  6. Dell Latitude 5480 Display Replacement: adım 6, 3 resimden 1. Dell Latitude 5480 Display Replacement: adım 6, 3 resimden 2. Dell Latitude 5480 Display Replacement: adım 6, 3 resimden 3.
    • Remove the four 5.6 mm Phillips head screws, one at each corner, to release the display assembly.
    • Gently lift away the display panel and set it on top of the keyboard.
    • Take care not to strain the display assemble cable.
  7. Dell Latitude 5480 Display Replacement: adım 7, 3 resimden 1. Dell Latitude 5480 Display Replacement: adım 7, 3 resimden 2. Dell Latitude 5480 Display Replacement: adım 7, 3 resimden 3.
    • On the bottom of the back of the display panel, remove the tape that secures the cable connecting the screen to the base of the computer.
    • Flip up the display cable locking bar.
    • Disconnect the display connector.
    • Remove the display.
Sonuç
Valencia Vidrine
457 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 53
