Ana içeriğe geç
Dell Latitude 5480 Fan Replacement
Neye ihtiyacın var
  1. Dell Latitude 5480 Fan Replacement, Lower Case: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Fan Replacement: adım 2, 3 resimden 1. Dell Latitude 5480 Fan Replacement: adım 2, 3 resimden 2. Dell Latitude 5480 Fan Replacement: adım 2, 3 resimden 3.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Fan Replacement, Dell Latitude 5480 Battery Disconnection: adım 3, 2 resimden 1. Dell Latitude 5480 Fan Replacement, Dell Latitude 5480 Battery Disconnection: adım 3, 2 resimden 2.
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  4. Dell Latitude 5480 Fan Replacement, Fan: adım 4, 3 resimden 1. Dell Latitude 5480 Fan Replacement, Fan: adım 4, 3 resimden 2. Dell Latitude 5480 Fan Replacement, Fan: adım 4, 3 resimden 3.
    • Remove the two 3.7 mm Phillips screws that secure the fan.
  5. Dell Latitude 5480 Fan Replacement: adım 5, 3 resimden 1. Dell Latitude 5480 Fan Replacement: adım 5, 3 resimden 2. Dell Latitude 5480 Fan Replacement: adım 5, 3 resimden 3.
    • Grip the fan connector and pull it directly out of its motherboard port.
    • Do not pull on the wires.
    • Lift the fan up and out of the chassis.
Sonuç
Valencia Vidrine
457 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 46
