Giriş
This guide provides steps users will have to take to replace the fan on their Dell Latitude 5480. Fans cool off the CPU, as well as other components in the computer, preventing them from overheating. If the fan is not working properly, or the computer frequently overheats, the fan will need to be replaced.
Neye ihtiyacın var
Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
