Ana içeriğe geç
Dell Latitude 5480 Power Jack Replacement
Neye ihtiyacın var
  1. Dell Latitude 5480 Power Jack Replacement, Lower Case: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Power Jack Replacement: adım 2, 3 resimden 1. Dell Latitude 5480 Power Jack Replacement: adım 2, 3 resimden 2. Dell Latitude 5480 Power Jack Replacement: adım 2, 3 resimden 3.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: adım 3, 2 resimden 1. Dell Latitude 5480 Power Jack Replacement, Dell Latitude 5480 Battery Disconnection: adım 3, 2 resimden 2.
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  4. Dell Latitude 5480 Power Jack Replacement, Power Jack: adım 4, 3 resimden 1. Dell Latitude 5480 Power Jack Replacement, Power Jack: adım 4, 3 resimden 2. Dell Latitude 5480 Power Jack Replacement, Power Jack: adım 4, 3 resimden 3.
    • Unscrew the right 3.7 mm screw that secures the fabric flap and the right side of the charging port bracket.
    • Carefully lift the flap out of the way of the left charging port bracket screw.
    • Unscrew the second 3.7 mm screw on the left side of the charging port bracket.
  5. Dell Latitude 5480 Power Jack Replacement: adım 5, 3 resimden 1. Dell Latitude 5480 Power Jack Replacement: adım 5, 3 resimden 2. Dell Latitude 5480 Power Jack Replacement: adım 5, 3 resimden 3.
    • Remove the metal bracket that secures the charging port.
    • Keep the fabric flap tucked out of the way.
    • Use the pointed edge of a spudger to push the charging port motherboard connector directly out of its port.
  6. Dell Latitude 5480 Power Jack Replacement: adım 6, 1 resimden 1.
    • Lift the entire charging port assembly up and out of the chassis.
Sonuç
Valencia Vidrine
457 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 58
