Ana içeriğe geç
Dell Latitude 5480 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude 5480 RAM Replacement, Lower Case: adım 1, 1 resimden 1.
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 RAM Replacement: adım 2, 3 resimden 1. Dell Latitude 5480 RAM Replacement: adım 2, 3 resimden 2. Dell Latitude 5480 RAM Replacement: adım 2, 3 resimden 3.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 RAM Replacement, Dell Latitude 5480 Battery Disconnection: adım 3, 2 resimden 1. Dell Latitude 5480 RAM Replacement, Dell Latitude 5480 Battery Disconnection: adım 3, 2 resimden 2.
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  4. Dell Latitude 5480 RAM Replacement, RAM: adım 4, 2 resimden 1. Dell Latitude 5480 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Two black clips secure each RAM module in place, one on each side. Use your fingers to spread the clips away from the RAM module.
    • Repeat the previous bullet on the second module.
    • When released, the RAM modules will pop up at a slight angle.
  5. Dell Latitude 5480 RAM Replacement: adım 5, 2 resimden 1. Dell Latitude 5480 RAM Replacement: adım 5, 2 resimden 2.
    • Pull the RAM module directly out of its port.
Sonuç
Valencia Vidrine
457 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 56
