Ana içeriğe geç
Dell Latitude 5580 Lower Case Replacement
Neye ihtiyacın var
  1. Dell Latitude 5580 Lower Case Replacement, Lower Case: adım 1, 3 resimden 1. Dell Latitude 5580 Lower Case Replacement, Lower Case: adım 1, 3 resimden 2. Dell Latitude 5580 Lower Case Replacement, Lower Case: adım 1, 3 resimden 3.
    • Orient your laptop so that you have access to the lower case, with the vents facing upwards.
    • Use a Phillips screwdriver to loosen the eight screws securing the bottom cover.
    • They are captive screws and do not fully come out of the holes. Don't force them or you may damage the screws or holes on the bottom case.
    • Insert the end of an iFixit opening tool or an opening pick into the seam between the bottom and top case to release the clips holding them together.
    • Slide the opening tool or pick around the edge of the laptop until the case is fully released.
    • Remove the lower case.
Sonuç
Connor Bassolino
22.054 İtibar
102 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 83
