Giriş
If your laptop battery fails or no longer holds a sufficient charge you can easily replace it. This guide will advise you on how to replace the battery.
Neye ihtiyacın var
Remove the following ten T5 screws securing the lower case to the upper case.
Two will be 6mm, eight will be 3mm in length.
2 farklı kişi bu kılavuzu tamamladı.
