Ana içeriğe geç
Dell Latitude 7350 Touch Screen Replacement
Neye ihtiyacın var
  1. Dell Latitude 7350 Touch Screen Replacement, Touch Screen: adım 1, 1 resimden 1.
    • Push down back-plate of the touch screen
  2. Dell Latitude 7350 Touch Screen Replacement: adım 2, 3 resimden 1. Dell Latitude 7350 Touch Screen Replacement: adım 2, 3 resimden 2. Dell Latitude 7350 Touch Screen Replacement: adım 2, 3 resimden 3.
    • Avoid static discharge by grounding yourself using a wrist grounding strap or by touching a bare metal surface like a connector on the back of the laptop. Remove all of the power including the battery and power adapter.
    • Unscrew and remove the battery.
  3. Dell Latitude 7350 Touch Screen Replacement: adım 3, 3 resimden 1. Dell Latitude 7350 Touch Screen Replacement: adım 3, 3 resimden 2. Dell Latitude 7350 Touch Screen Replacement: adım 3, 3 resimden 3.
    • Open the cover of the screen.
    • Remove the wide head.
  4. Dell Latitude 7350 Touch Screen Replacement: adım 4, 2 resimden 1. Dell Latitude 7350 Touch Screen Replacement: adım 4, 2 resimden 2.
    • Take off the screen battery.
    • Remove the following screw.
  5. Dell Latitude 7350 Touch Screen Replacement: adım 5, 3 resimden 1. Dell Latitude 7350 Touch Screen Replacement: adım 5, 3 resimden 2. Dell Latitude 7350 Touch Screen Replacement: adım 5, 3 resimden 3.
    • Unscrew and remove SSD from motherboard.
    • Disconnect then unscrew and remove audio circuit board.
Sonuç
Faisal Alohali
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 382
