Ana içeriğe geç
Dell Latitude 7390 (2-in-1) Bottom Panel Replacement
Neye ihtiyacın var
  1. Dell Latitude 7390 (2-in-1) Bottom Panel Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 (2-in-1) Bottom Panel Replacement: adım 2, 3 resimden 1. Dell Latitude 7390 (2-in-1) Bottom Panel Replacement: adım 2, 3 resimden 2. Dell Latitude 7390 (2-in-1) Bottom Panel Replacement: adım 2, 3 resimden 3.
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 (2-in-1) Bottom Panel Replacement: adım 3, 1 resimden 1.
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 (2-in-1) Bottom Panel Replacement: adım 4, 2 resimden 1. Dell Latitude 7390 (2-in-1) Bottom Panel Replacement: adım 4, 2 resimden 2.
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 (2-in-1) Bottom Panel Replacement: adım 5, 1 resimden 1.
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Julia Blahut
390 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-4, Hunter Spring 2022 Clemson, Team 1-4, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S1G4
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 54
Her zaman: 993
