Giriş
If you need to repair or replace the fan component in the Dell Latitude 7390, this guide shows you step-by-step how to access it.
Prior to starting this repair, be sure to turn off your laptop and unplug from the power adapter.
Neye ihtiyacın var
Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
Remove the five black screws holding the fan and heatsink in place using the Phillips #0 screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
