Ana içeriğe geç
Dell Latitude 7390 Fan Replacement
Neye ihtiyacın var
  1. Dell Latitude 7390 Fan Replacement, Bottom Panel: adım 1, 1 resimden 1.
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 Fan Replacement: adım 2, 3 resimden 1. Dell Latitude 7390 Fan Replacement: adım 2, 3 resimden 2. Dell Latitude 7390 Fan Replacement: adım 2, 3 resimden 3.
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 Fan Replacement: adım 3, 1 resimden 1.
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 Fan Replacement: adım 4, 2 resimden 1. Dell Latitude 7390 Fan Replacement: adım 4, 2 resimden 2.
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 Fan Replacement: adım 5, 1 resimden 1.
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 Fan Replacement, Battery: adım 6, 1 resimden 1.
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 Fan Replacement: adım 7, 3 resimden 1. Dell Latitude 7390 Fan Replacement: adım 7, 3 resimden 2. Dell Latitude 7390 Fan Replacement: adım 7, 3 resimden 3.
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 Fan Replacement: adım 8, 1 resimden 1.
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 Fan Replacement, Fan: adım 9, 1 resimden 1.
    • Remove the five black screws holding the fan and heatsink in place using the Phillips #0 screwdriver.
  10. Dell Latitude 7390 Fan Replacement: adım 10, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers or your fingers to disconnect the fan connector.
  11. Dell Latitude 7390 Fan Replacement: adım 11, 1 resimden 1.
    • Remove the fan from the case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Glennjay Elayda
246 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-4, Hunter Spring 2022 Clemson, Team 1-4, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S1G4
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 31
Son 30 gün: 85
Her zaman: 2,496
