Giriş
If you need to replace the Wi-Fi chip within your Dell latitude 7390, follow this guide.
Before beginning this repair, be sure to power off your laptop and disconnect from the power adapter.
Neye ihtiyacın var
Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
Using a Phillips #1 screwdriver, remove the 3 mm screw securing the Wi-Fi card.
