Ana içeriğe geç
Dell Latitude 7420 Battery Replacement
Neye ihtiyacın var
  1. Dell Latitude 7420 Battery Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude 7420 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
  2. Dell Latitude 7420 Battery Replacement: adım 2, 2 resimden 1. Dell Latitude 7420 Battery Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
  3. Dell Latitude 7420 Battery Replacement: adım 3, 2 resimden 1. Dell Latitude 7420 Battery Replacement: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
  4. Dell Latitude 7420 Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery from the motherboard by gently pulling out the connector.
  5. Dell Latitude 7420 Battery Replacement: adım 5, 2 resimden 1. Dell Latitude 7420 Battery Replacement: adım 5, 2 resimden 2.
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Hong Lee
208 İtibar
1 Kılavuz yazıldı
Bir Yorum
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 88
Son 30 gün: 372
Her zaman: 11,093
