Giriş
Use this guide to replace the display of the Dell Latitude 9410 2-in-1. Screen abnormalities such as flickering, horizontal or vertical lines, or color fades may indicate a faulty display.
Neye ihtiyacın var
Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
Carefully detach the ribbon that is affixed to the HDD.
Using a Philips #00 screwdriver, unscrew the 3, top left and top right 4mm screws located about the hinge.
