Ana içeriğe geç
Dell Latitude 9410 2-in-1 Fan Replacement
Neye ihtiyacın var
  1. Dell Latitude 9410 2-in-1 Fan Replacement, Base Panel: adım 1, 1 resimden 1.
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Fan Replacement: adım 2, 2 resimden 1. Dell Latitude 9410 2-in-1 Fan Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Fan Replacement: adım 3, 3 resimden 1. Dell Latitude 9410 2-in-1 Fan Replacement: adım 3, 3 resimden 2. Dell Latitude 9410 2-in-1 Fan Replacement: adım 3, 3 resimden 3.
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Fan Replacement, Fan: adım 4, 3 resimden 1. Dell Latitude 9410 2-in-1 Fan Replacement, Fan: adım 4, 3 resimden 2. Dell Latitude 9410 2-in-1 Fan Replacement, Fan: adım 4, 3 resimden 3.
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 Fan Replacement: adım 5, 2 resimden 1. Dell Latitude 9410 2-in-1 Fan Replacement: adım 5, 2 resimden 2.
    • Use a Philips #00 screwdriver to remove the two 2 mm screws.
    • After the screws are removed, lift off the silver bracket, toward the top left of the fan.
  6. Dell Latitude 9410 2-in-1 Fan Replacement: adım 6, 2 resimden 1. Dell Latitude 9410 2-in-1 Fan Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Grip both sides of the fan connector plug with tweezers, and pull directly backwards, toward the cables, until the plug disconnects.
  7. Dell Latitude 9410 2-in-1 Fan Replacement: adım 7, 2 resimden 1. Dell Latitude 9410 2-in-1 Fan Replacement: adım 7, 2 resimden 2.
    • Lift the fan up and out.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 21
Her zaman: 437
