Ana içeriğe geç
Dell Latitude 9410 2-in-1 SSD Replacement
Neye ihtiyacın var
  1. Dell Latitude 9410 2-in-1 SSD Replacement, Base Panel: adım 1, 1 resimden 1.
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 SSD Replacement: adım 2, 2 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 SSD Replacement: adım 3, 3 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement: adım 3, 3 resimden 2. Dell Latitude 9410 2-in-1 SSD Replacement: adım 3, 3 resimden 3.
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: adım 4, 3 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: adım 4, 3 resimden 2. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: adım 4, 3 resimden 3.
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 SSD Replacement: adım 5, 3 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement: adım 5, 3 resimden 2. Dell Latitude 9410 2-in-1 SSD Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the 2 mm screw, loosening the bracket that covers the SSD.
    • Carefully lift the off the bracket.
    • The bracket is attached to the laptop and cannot be removed completely.
  6. Dell Latitude 9410 2-in-1 SSD Replacement: adım 6, 3 resimden 1. Dell Latitude 9410 2-in-1 SSD Replacement: adım 6, 3 resimden 2. Dell Latitude 9410 2-in-1 SSD Replacement: adım 6, 3 resimden 3.
    • Grip the SSD and pull directly backward until the SSD releases from its port.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 42
Her zaman: 1,257
