Neye ihtiyacın var
Flip the device so that the base plate is facing you.
Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
Use a Phillips #0 screwdriver to remove the four 3.5 mm screws.
Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
Use a Phillips #00 screwdriver to remove the four screws.
Use a Phillips #00 screwdriver to remove the three screws.
