Ana içeriğe geç
Dell Latitude D430 Wireless Adapter Replacement
Neye ihtiyacın var
  1. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: adım 1, 3 resimden 1. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: adım 1, 3 resimden 2. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: adım 1, 3 resimden 3.
    • Flip the laptop so you are able to see the bottom.
  2. Dell Latitude D430 Wireless Adapter Replacement: adım 2, 2 resimden 1. Dell Latitude D430 Wireless Adapter Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the three screws that secure the small "L" shaped backplate.
  3. Dell Latitude D430 Wireless Adapter Replacement: adım 3, 1 resimden 1.
    • Once all 3 screws have been removed, carefully remove the panel by grabbing the edges, and pulling up.
  4. Dell Latitude D430 Wireless Adapter Replacement: adım 4, 3 resimden 1. Dell Latitude D430 Wireless Adapter Replacement: adım 4, 3 resimden 2. Dell Latitude D430 Wireless Adapter Replacement: adım 4, 3 resimden 3.
    • Identify the two pins connecting the wireless adapter to the motherboard. (The wireless adapter will say WLAN on it.)
    • Carefully pull up on each pin and remove them from the wireless adapter.
    • Note that there are no wires/cables connecting the wireless adapter to the motherboard.
  5. Dell Latitude D430 Wireless Adapter Replacement: adım 5, 2 resimden 1. Dell Latitude D430 Wireless Adapter Replacement: adım 5, 2 resimden 2.
    • Pull back on the two metal tabs holding the wireless adapter down.
    • After the two metal tabs are pulled, the card will pop up.
  6. Dell Latitude D430 Wireless Adapter Replacement: adım 6, 1 resimden 1.
    • Pull the wireless adapter out away from where it was connected.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 32
Her zaman: 580
