Ana içeriğe geç
Dell Latitude D520 disassembly and power jack repair
Neye ihtiyacın var
  1. Dell Latitude D520 disassembly and power jack repair, Power Jack: adım 1, 1 resimden 1.
    • 1. unplug laptop
    • 2. remove battery
    • 3. remove screw
    • Remove disk drive by pressing in the pull mechanism, causing it to extend outwards, then use the pull handle to pull out disk drive.
    FixBot'a Sor
  2. Dell Latitude D520 disassembly and power jack repair: adım 2, 1 resimden 1.
    • remove 2 retention screws
    • slide HD carriage out
    FixBot'a Sor
  3. Dell Latitude D520 disassembly and power jack repair: adım 3, 1 resimden 1.
    • open laptop
    • with a small screwdriver carefully pry plastic cover
    • it helps to open the laptop all the way
    • be careful not to break these clips
    • The clips found under here were specially tricky
    FixBot'a Sor
  4. Dell Latitude D520 disassembly and power jack repair: adım 4, 3 resimden 1. Dell Latitude D520 disassembly and power jack repair: adım 4, 3 resimden 2. Dell Latitude D520 disassembly and power jack repair: adım 4, 3 resimden 3.
    • remove screws X 2
    • carefully lift keyboard, being careful not to damage the flat cable.
    • lift up tab to release flat cable and remove keyboard
    FixBot'a Sor
  5. Dell Latitude D520 disassembly and power jack repair: adım 5, 3 resimden 1. Dell Latitude D520 disassembly and power jack repair: adım 5, 3 resimden 2. Dell Latitude D520 disassembly and power jack repair: adım 5, 3 resimden 3.
    • disconnect the three wires
    • disconnect video connector
    • remove ground screw
    • remove 3 screws
    • remove last screw, note this screw is longer then the other three
    • remove screen
    FixBot'a Sor
  6. Dell Latitude D520 disassembly and power jack repair: adım 6, 3 resimden 1. Dell Latitude D520 disassembly and power jack repair: adım 6, 3 resimden 2. Dell Latitude D520 disassembly and power jack repair: adım 6, 3 resimden 3.
    • Remove these 15 screws, they are all the same size
    • remove screw and cover
    • flip the laptop over
    • remove touchpad flat cable by gently pulling up.
    • remove 4 screws marked with the letter P
    FixBot'a Sor
  7. Dell Latitude D520 disassembly and power jack repair: adım 7, 1 resimden 1.
    • remove top cover being careful not to break any clips
    FixBot'a Sor
  8. Dell Latitude D520 disassembly and power jack repair: adım 8, 2 resimden 1. Dell Latitude D520 disassembly and power jack repair: adım 8, 2 resimden 2.
    • remove 3 screws
    • carefully remove small metal piece that was being help down by the three screws
    FixBot'a Sor
  9. Dell Latitude D520 disassembly and power jack repair: adım 9, 2 resimden 1. Dell Latitude D520 disassembly and power jack repair: adım 9, 2 resimden 2.
    • remove 4 screws
    • remove 1 screw
    • being careful not to break any clips, separate bottom plastic cover from the mother board carriage.
    FixBot'a Sor
  10. Dell Latitude D520 disassembly and power jack repair: adım 10, 1 resimden 1.
    • The middle part of my power connector had sheared away from its solder points on the motherboard.
    • I had to use a bit of flux, but I managed to re-tin all three contact point on the motherboard, as well as the pins in the connector.
    • I re-soldered the whole thing and used my trusty hot glue gun to encase the whole connector to prevent it from happening again anytime soon.
    FixBot'a Sor
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
otrebla
323 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 71
Her zaman: 10,219
