Ana içeriğe geç
Dell Latitude D600 Display Replacement
Neye ihtiyacın var
  1. Dell Latitude D600 Display Replacement, Display: adım 1, 1 resimden 1.
    • Remove the 6 screws underneath the rubber things - located in red
  2. Dell Latitude D600 Display Replacement: adım 2, 2 resimden 1. Dell Latitude D600 Display Replacement: adım 2, 2 resimden 2.
    • Use your spudger to pry off the front case
    • Go all around the perimeter and pop it off
  3. Dell Latitude D600 Display Replacement: adım 3, 1 resimden 1.
    • Remove the 6 screws holding in the display screen
  4. Dell Latitude D600 Display Replacement: adım 4, 3 resimden 1. Dell Latitude D600 Display Replacement: adım 4, 3 resimden 2. Dell Latitude D600 Display Replacement: adım 4, 3 resimden 3.
    • Remove the screw holding in the display cable connector
    • Pull the black tab up to remove the display cable connector
  5. Dell Latitude D600 Display Replacement: adım 5, 1 resimden 1.
    • Slowly Remove the wire from the joints holding it in
  6. Dell Latitude D600 Display Replacement: adım 6, 2 resimden 1. Dell Latitude D600 Display Replacement: adım 6, 2 resimden 2.
    • The computer is happy you are fixing him
    • Thats it, display is now removed feel free to replace it by doing the steps in reverse
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Joseph
1.497 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
I see you removed the keyboard by seeing it in the background of the last image however, I do not see the steps instructing everyone on how to remove the keyboard.
Darren - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 2,074
