Giriş
This guide will show how to add RAM or replace existing RAM on the Latitude D600
Parçalar
Hiçbir parçaya gerek yok.
  1. Find the battery
    • Find the battery
  2. Pull the tab to release the battery Pull the tab to release the battery
    • Pull the tab to release the battery
  3. Pull the battery out
    • Pull the battery out
  4. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Find the panel underneath the microsoft product key sticker, the panel is labeled with an M Unscrew the single screw above the M
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  6. Pull off the panel to reveal the RAM RAM is held in by two tabs, pull each tab to the side and the RAM will pop up RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  7. Once the RAM is popped up, slowly pull it out of the slot
    • Once the RAM is popped up, slowly pull it out of the slot
  8. To add or replace RAM, place the memory into the slot at an angle Make sure you line it up correctly If it is in correctly it should stay up at an angle by itself
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  9. The RAM should be secured by the tabs where the two semi circles are on the RAM
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
Sonuç
5 başka kişi bu kılavuzu tamamladı.
Joseph
1.427 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
Almost perfect: easy; clear;
Herman - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 21
Her zaman: 2,046
