Ana içeriğe geç
Dell Latitude D600 RAM (Main Memory) Replacement
Neye ihtiyacın var
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: adım 1, 1 resimden 1.
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: adım 2, 2 resimden 1. Dell Latitude D600 RAM (Main Memory) Replacement: adım 2, 2 resimden 2.
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: adım 3, 1 resimden 1.
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): adım 4, 2 resimden 1. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): adım 4, 2 resimden 2.
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: adım 5, 3 resimden 1. Dell Latitude D600 RAM (Main Memory) Replacement: adım 5, 3 resimden 2. Dell Latitude D600 RAM (Main Memory) Replacement: adım 5, 3 resimden 3.
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: adım 6, 1 resimden 1.
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: adım 7, 3 resimden 1. Dell Latitude D600 RAM (Main Memory) Replacement: adım 7, 3 resimden 2. Dell Latitude D600 RAM (Main Memory) Replacement: adım 7, 3 resimden 3.
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: adım 8, 1 resimden 1.
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Joseph
1.497 İtibar
5 adet Kılavuz yazıldı
1Rehber Yorum
Almost perfect: easy; clear;
Herman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 3,016
