Ana içeriğe geç
Dell Latitude D600 Wireless WiFi Card Replacement
Neye ihtiyacın var
  1. Dell Latitude D600 Wireless WiFi Card Replacement, Battery: adım 1, 1 resimden 1.
    • Find the battery
  2. Dell Latitude D600 Wireless WiFi Card Replacement: adım 2, 2 resimden 1. Dell Latitude D600 Wireless WiFi Card Replacement: adım 2, 2 resimden 2.
    • Pull the tab to release the battery
  3. Dell Latitude D600 Wireless WiFi Card Replacement: adım 3, 1 resimden 1.
    • Pull the battery out
  4. Dell Latitude D600 Wireless WiFi Card Replacement, Wireless WiFi Card: adım 4, 1 resimden 1.
    • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  5. Dell Latitude D600 Wireless WiFi Card Replacement: adım 5, 1 resimden 1.
    • Pull off the two wires connected to the wireless card
    • They should come off fairly easy
  6. Dell Latitude D600 Wireless WiFi Card Replacement: adım 6, 2 resimden 1. Dell Latitude D600 Wireless WiFi Card Replacement: adım 6, 2 resimden 2.
    • Pull the two tabs away from the card and pull up on the intel card
    • Then pull it away from the holding slot to remove it
  7. Dell Latitude D600 Wireless WiFi Card Replacement: adım 7, 2 resimden 1. Dell Latitude D600 Wireless WiFi Card Replacement: adım 7, 2 resimden 2.
    • When placing in your new wireless card, connect the two wires before inserting into the slot
    • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Joseph
1.497 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
Hi,
dell latitude D600 Laptop
Can you please help me, I cant release my wireless card, by pulling the tabs on cards sides.?
It just doesn't release the card to pull out, is there any other way I can remove my card.?
Email me if you can .
robert.wilson407@ntlworld.com
Thanking you Rob
rob wilson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 2,632
