Ana içeriğe geç
Dell Latitude D610 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Latitude D610 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude D610 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Keyboard Replacement: adım 2, 3 resimden 1. Dell Latitude D610 Keyboard Replacement: adım 2, 3 resimden 2. Dell Latitude D610 Keyboard Replacement: adım 2, 3 resimden 3.
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Keyboard Replacement: adım 3, 1 resimden 1.
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Keyboard Replacement, Keyboard: adım 4, 3 resimden 1. Dell Latitude D610 Keyboard Replacement, Keyboard: adım 4, 3 resimden 2. Dell Latitude D610 Keyboard Replacement, Keyboard: adım 4, 3 resimden 3.
    • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
  5. Dell Latitude D610 Keyboard Replacement: adım 5, 2 resimden 1. Dell Latitude D610 Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
  6. Dell Latitude D610 Keyboard Replacement: adım 6, 2 resimden 1. Dell Latitude D610 Keyboard Replacement: adım 6, 2 resimden 2.
    • Using an opening tool, carefully release the keyboard from the case.
    • Making sure not to tear or damage the wires still connecting it to the laptop.
  7. Dell Latitude D610 Keyboard Replacement: adım 7, 3 resimden 1. Dell Latitude D610 Keyboard Replacement: adım 7, 3 resimden 2. Dell Latitude D610 Keyboard Replacement: adım 7, 3 resimden 3.
    • Carfully lift the key board.
    • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
    • Pull on the blue tab to unplug the keyboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jordan Barham
459 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-24, Maness Winter 2014 Cal Poly, Team 6-24, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G24
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 1,972
