Ana içeriğe geç
Dell Latitude D610 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude D610 RAM Replacement, Battery: adım 1, 2 resimden 1. Dell Latitude D610 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 RAM Replacement: adım 2, 3 resimden 1. Dell Latitude D610 RAM Replacement: adım 2, 3 resimden 2. Dell Latitude D610 RAM Replacement: adım 2, 3 resimden 3.
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 RAM Replacement: adım 3, 1 resimden 1.
    • Remove the battery from its compartment.
  4. Dell Latitude D610 RAM Replacement, RAM: adım 4, 3 resimden 1. Dell Latitude D610 RAM Replacement, RAM: adım 4, 3 resimden 2. Dell Latitude D610 RAM Replacement, RAM: adım 4, 3 resimden 3.
    • Remove the 3.9mm Philips #1 screw holding the panel for the RAM.
  5. Dell Latitude D610 RAM Replacement: adım 5, 2 resimden 1. Dell Latitude D610 RAM Replacement: adım 5, 2 resimden 2.
    • Lift and remove the panel.
  6. Dell Latitude D610 RAM Replacement: adım 6, 3 resimden 1. Dell Latitude D610 RAM Replacement: adım 6, 3 resimden 2. Dell Latitude D610 RAM Replacement: adım 6, 3 resimden 3.
    • Using two fingers, push the silver ends away from the RAM until the RAM is released.
  7. Dell Latitude D610 RAM Replacement: adım 7, 3 resimden 1. Dell Latitude D610 RAM Replacement: adım 7, 3 resimden 2. Dell Latitude D610 RAM Replacement: adım 7, 3 resimden 3.
    • Lift the RAM from its slot.
    • Remove the RAM completely.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jordan Barham
459 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-24, Maness Winter 2014 Cal Poly, Team 6-24, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G24
4 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
This model has two RAM slots. The second one is under the keypad. Carefully remove the bezel at the top of the keypad, remove the two screws holding the keypad down, then remove the keypad to expose the second slot. This RAM slot is a little bit more difficult to get to than the one on the back of the laptop, but is still very easy to access and change out.
Chris Kelley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,640
