Ana içeriğe geç
Dell Latitude D620 CD Drive Replacement
Neye ihtiyacın var
    1. Dell Latitude D620 CD Drive Replacement, Keyboard: adım 1, 1 resimden 1.
      • Power down the laptop and remove the battery.
      • Open the laptop cover all of the way.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Latitude D620 CD Drive Replacement: adım 2, 3 resimden 1. Dell Latitude D620 CD Drive Replacement: adım 2, 3 resimden 2. Dell Latitude D620 CD Drive Replacement: adım 2, 3 resimden 3.
      • Locate the notch under the cover at the top of the keyboard
      • Using the spudger as a lever, lift the plastic covering
      • Carefully remove the rest of the covering from right to left
      FixBot'a Sor
      Yorum Ekle
    3. Dell Latitude D620 CD Drive Replacement: adım 3, 1 resimden 1.
      • Unscrew the top portion of the keyboard using a #00 screwdriver
      FixBot'a Sor
      Yorum Ekle
    4. Dell Latitude D620 CD Drive Replacement: adım 4, 1 resimden 1.
      • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
      • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
      FixBot'a Sor
      Yorum Ekle
    5. Dell Latitude D620 CD Drive Replacement: adım 5, 2 resimden 1. Dell Latitude D620 CD Drive Replacement: adım 5, 2 resimden 2.
      • Once keyboard is out of the case, lay it face-down on the track pad
      FixBot'a Sor
      Yorum Ekle
    6. Dell Latitude D620 CD Drive Replacement: adım 6, 2 resimden 1. Dell Latitude D620 CD Drive Replacement: adım 6, 2 resimden 2.
      • Using a small spudger, pull back on the black bar to release the blue lever
      FixBot'a Sor
      Yorum Ekle
    7. Dell Latitude D620 CD Drive Replacement: adım 7, 1 resimden 1.
      • Pull up on the metal bar connected to the socket to detach the ribbon cable
      FixBot'a Sor
      Yorum Ekle
    1. Dell Latitude D620 CD Drive Replacement, CD Drive: adım 8, 2 resimden 1. Dell Latitude D620 CD Drive Replacement, CD Drive: adım 8, 2 resimden 2.
      • Press in the tab on the bottom right side of the CD drive
      • The tab comes out on its own; there is no need to pull it out manually.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Latitude D620 CD Drive Replacement: adım 9, 1 resimden 1.
      • Gently pull the tab to remove the disk tray.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Ivan
203 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G35
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 56
Her zaman: 9,054
