Ana içeriğe geç
Dell Latitude D620 Display Replacement
Neye ihtiyacın var
  1. Dell Latitude D620 Display Replacement, Keyboard: adım 1, 1 resimden 1.
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
    Please help me
    manaqib arif - Yanıt
    Mera display ka masla hai
  2. Dell Latitude D620 Display Replacement: adım 2, 3 resimden 1. Dell Latitude D620 Display Replacement: adım 2, 3 resimden 2. Dell Latitude D620 Display Replacement: adım 2, 3 resimden 3.
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Display Replacement: adım 3, 1 resimden 1.
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Display Replacement: adım 4, 1 resimden 1.
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Display Replacement: adım 5, 2 resimden 1. Dell Latitude D620 Display Replacement: adım 5, 2 resimden 2.
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Display Replacement: adım 6, 2 resimden 1. Dell Latitude D620 Display Replacement: adım 6, 2 resimden 2.
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Display Replacement: adım 7, 1 resimden 1.
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 Display Replacement, Display: adım 8, 1 resimden 1.
    • Detach cables that connect the display to the body of the laptop
  9. Dell Latitude D620 Display Replacement: adım 9, 1 resimden 1.
    • Disconnect the black cable attached to the motherboard
  10. Dell Latitude D620 Display Replacement: adım 10, 2 resimden 1. Dell Latitude D620 Display Replacement: adım 10, 2 resimden 2.
    • Close the laptop lid
    • Turn the laptop over onto its backside
    • Unscrew the two screws shown in the picture using a #00 screwdriver
  11. Dell Latitude D620 Display Replacement: adım 11, 2 resimden 1. Dell Latitude D620 Display Replacement: adım 11, 2 resimden 2.
    • Face the laptop's back ports towards you
    • Unscrew the two screws labeled in the picture using a #00 screwdriver
  12. Dell Latitude D620 Display Replacement: adım 12, 1 resimden 1.
    • Turn the laptop over again so it's right-side up
    • Open the display, and pull the display up and out of the laptop's body
  13. Dell Latitude D620 Display Replacement: adım 13, 1 resimden 1.
    • Remove the circular rubber pads as outlined in the picture using a spudger
  14. Dell Latitude D620 Display Replacement: adım 14, 1 resimden 1.
    • Unscrew the screws that were under the rubber circles using the #00 screwdriver
  15. Dell Latitude D620 Display Replacement: adım 15, 1 resimden 1.
    • Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
    • Be very careful while doing this as the plastic snaps easily
  16. Dell Latitude D620 Display Replacement: adım 16, 1 resimden 1.
    • Remove the screws outlined in the picture
  17. Dell Latitude D620 Display Replacement: adım 17, 1 resimden 1.
    • Carefully lift the LCD screen out of its casing
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Miguel Wong
562 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G35
4 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
Check out this replacement screen at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 45
Her zaman: 33,241
