Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Guide to removing the keyboard from the D620.
Parçalar
Hiçbir parça belirtilmedi.
  1. Power down the laptop and remove the battery.
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Locate the notch under the cover at the top of the keyboard Using the spudger as a lever, lift the plastic covering Carefully remove the rest of the covering from right to left
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Unscrew the top portion of the keyboard using a #00 screwdriver
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  5. Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  6. Once keyboard is out of the case, lay it face-down on the track pad Once keyboard is out of the case, lay it face-down on the track pad
    • Once keyboard is out of the case, lay it face-down on the track pad
  7. Using a small spudger, pull back on the black bar to release the blue lever Using a small spudger, pull back on the black bar to release the blue lever
    • Using a small spudger, pull back on the black bar to release the blue lever
  8. Pull up on the metal bar connected to the socket to detach the ribbon cable
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Miguel Wong
466 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G35
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Check out this keyboard at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 15,829
