Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate the notch under the cover at the top of the keyboard
Using the spudger as a lever, lift the plastic covering
Carefully remove the rest of the covering from right to left
Unscrew the top portion of the keyboard using a #00 screwdriver
Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
Once keyboard is out of the case, lay it face-down on the track pad
Using a small spudger, pull back on the black bar to release the blue lever
Pull up on the metal bar connected to the socket to detach the ribbon cable
10 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Check out this keyboard at a great price on bcdelectrostore.com
