Ana içeriğe geç
Dell Latitude D620 RAM Replacement
Neye ihtiyacın var
  1. Dell Latitude D620 RAM Replacement, Keyboard: adım 1, 1 resimden 1.
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Latitude D620 RAM Replacement: adım 2, 3 resimden 1. Dell Latitude D620 RAM Replacement: adım 2, 3 resimden 2. Dell Latitude D620 RAM Replacement: adım 2, 3 resimden 3.
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
    FixBot'a Sor
    Yorum Ekle
  3. Dell Latitude D620 RAM Replacement: adım 3, 1 resimden 1.
    • Unscrew the top portion of the keyboard using a #00 screwdriver
    FixBot'a Sor
    Yorum Ekle
  4. Dell Latitude D620 RAM Replacement: adım 4, 1 resimden 1.
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
    FixBot'a Sor
    Yorum Ekle
  5. Dell Latitude D620 RAM Replacement: adım 5, 2 resimden 1. Dell Latitude D620 RAM Replacement: adım 5, 2 resimden 2.
    • Once keyboard is out of the case, lay it face-down on the track pad
    FixBot'a Sor
    Yorum Ekle
  6. Dell Latitude D620 RAM Replacement: adım 6, 2 resimden 1. Dell Latitude D620 RAM Replacement: adım 6, 2 resimden 2.
    • Using a small spudger, pull back on the black bar to release the blue lever
    FixBot'a Sor
    Yorum Ekle
  7. Dell Latitude D620 RAM Replacement: adım 7, 1 resimden 1.
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
    FixBot'a Sor
    Yorum Ekle
  8. Dell Latitude D620 RAM Replacement, RAM: adım 8, 2 resimden 1. Dell Latitude D620 RAM Replacement, RAM: adım 8, 2 resimden 2.
    • With the keyboard removed, you should be able to see ram slot A.
    • Place new ram into the slot making sure it is aligned
    FixBot'a Sor
    Yorum Ekle
  9. Dell Latitude D620 RAM Replacement: adım 9, 1 resimden 1.
    • Replace the keyboard by following the previous steps in reverse
    • Close the laptop, and flip it over onto its backside
    FixBot'a Sor
    Yorum Ekle
  10. Dell Latitude D620 RAM Replacement: adım 10, 2 resimden 1. Dell Latitude D620 RAM Replacement: adım 10, 2 resimden 2.
    • Loosen the screw that holds the RAM cover in place.
    • The screw cannot be fully removed since it is attached to the RAM cover.
    FixBot'a Sor
    Yorum Ekle
  11. Dell Latitude D620 RAM Replacement: adım 11, 2 resimden 1. Dell Latitude D620 RAM Replacement: adım 11, 2 resimden 2.
    • Insert new ram into slot B
    FixBot'a Sor
    Yorum Ekle
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
Miguel Wong
565 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G35
4 Üyeler
4 adet Kılavuz yazıldı
2Kılavuz Yorumları
If you are increasing the amount of RAM installed -> On first power on after installing the RAM, system on boot up will complain about memory size changed, and to reseat the memory. Wait for about 60 - 90 seconds, and you will receive a few additional messages about F1 to continue or F2 for Setup. Go into Setup and verify that the system sees all memory installed. If installing 2 x 2GB DDR2, max possible, 4GB. BIOS setup should report 4GB installed, of which 3.37GB usable.
Michael Erwin - Yanıt Paylaş
J’étais inquiet, mais en lisant votre commentaire, me voilà rassuré et j’ai donc suivi vos instructions. Ca fonctionne 2X2 GO …Merci
ppgauchard - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 68
Her zaman: 35,336
